10-27-2004 08:31 AM - edited 03-02-2019 07:34 PM
One of the scopes that is configured in DHCP is not being used. My thinking is that there might be a problem on the switch, which it is not switching between the three scopes that I have configured? Can you provide me some tips? I don't know much about tweaking the configuration on a switch to get it to switch between scopes. Thanks much.
10-27-2004 10:16 AM
Do you have a VLAN interface configured?
This config should work:
int g 2/0
switchport access vlan 200
interface vlan 200
ip address 2.2.2.1 255.255.255.0
ip dhcp pool v200
network 2.2.2.0 255.255.255.0
dns-server 1.1.1.1
default-router 2.2.2.1
HTH!
10-27-2004 11:54 AM
Yes, we have three vlans. Thanks for your input!
