Community Helping Community
3525
Highlighted
System received a Bus Error exception
when i turn on my UC540 it shows this log and get into rommon mode.
I reinstalled the ios with tftpdnld, and still equal
************************************** LOG **************************************************
System Bootstrap, Version 12.4(24r)SB, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
UC500 series platform with 262144 Kbytes of main memory
Readonly ROMMON initialized
program load complete, entry point: 0x80015000, size: 0xb700
program load complete, entry point: 0x80020000, size: 0x25aa110
Self decompressing the image : ############################################################################################################################################################################################################################################################################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
                0X000034A0 Onboard Modules/WICs
                0X00063E08 Onboard Wireless
                0X00137430 Onboard PVDM2 SIMM
                0X00118500 Onboard Ethernet
                0X0011D000 Onboard VPN
                0X000F3BB0 public buffer pools
                0X00703000 public particle pools
TOTAL:          0X00BCA788
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 11Mb.
adjusted iomem size up to minimum size of: 0X01A00000
Using 10 percent iomem. [26Mb/256Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 12-Jul-11 22:01 by prod_rel_team
10:25:27 UTC Thu May 3 2012: Unexpected exception to CPU: vector 200, PC = 0x802D6554, LR = 0x800307C8
-Traceback= 0x802D6554z 0x800307C8z 0x80CFF47Cz 0x80CFF590z 0x82CE7DE8z 0x82CE7E9Cz 0x82CE8008z 0x81520948z 0x81520BECz 0x802D5BF4z 0x802BC3F4z
CPU Register Context:
MSR = 0x00049030  CR  = 0x88008024  CTR = 0x80026E58  XER   = 0x20000000
R0  = 0x00008000  R1  = 0x8611BFE8  R2  = 0xFFF5FFF5  R3    = 0x00001002
R4  = 0x00000000  R5  = 0x04980000  R6  = 0x00000080  R7    = 0xF0000000
R8  = 0x04FFFFFF  R9  = 0xF0010000  R10 = 0x00000000  R11   = 0x850B0000
R12 = 0x88008082  R13 = 0xFFF56988  R14 = 0x81520B80  R15   = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19   = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23   = 0x00000000
R24 = 0x00000000  R25 = 0x00000004  R26 = 0x00000000  R27   = 0x00000004
R28 = 0x00000000  R29 = 0x00000013  R30 = 0x857E0000  R31   = 0x85421B40
TEXT_START : 0x800200F0
DATA_START : 0x83C693BC
Writing crashinfo to flash:crashinfo_20120503-102527-UTC
=== Flushing messages (10:25:28 UTC Thu May 3 2012) ===
Queued messages:
*May  3 10:25:28.731: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*May  3 10:25:27.643: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*May  3 10:25:28.071: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*May  3 10:25:28.083: %LINK-3-UPDOWN: Interface Integrated-Service-Engine0/0, changed state to up
No warm reboot Storage
*** System received a Bus Error exception ***
signal= 0xa, code= 0x200, context= 0x85a28050
PC = 0x802d6554, Vector = 0x200, SP = 0x8611bfe8
rommon 1 >
1 REPLY 1
Beginner
Remove all of your cards/etc from the chassis, try rebooting. Does it work? If yes, reinsert one card at a time until you find what is causing the problem. If that doesn't work, try opening the chassis and reseating any loose modules such as CPU, memory, AIM modules, whatever.
If you open the chassis, reinsert all modules, remove all cards, and it still won't boot... contact TAC, you will probably have to RMA due to a hardware failure.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800cdd51.shtml
Content for Community-Ad
FusionCharts will render here
