12-29-2003 12:05 AM - edited 03-02-2019 12:35 PM
Hello :
Somebody know anu tool to see load charge ( not command ) on Catalyst 6500 at different times.
12-29-2003 12:55 AM
you can use MRTG, a freeware tool that can read any value on the 6500 that has an OID.
Check this website for information on how to install MRTG:
Let me know if you need help with the configuration.
GP
12-29-2003 03:12 AM
Hello Gpauwen:
Thanks for your reply, I have a lot of problems for install and run with perl.
You know another tool don't ussing perl?
Thnaks and regards
Mauricio
01-05-2004 02:54 AM
We use a combination of MRTG and Solarwinds (http://www.solarwinds.net/Toolsets.htm) which may be closer to what you need.
01-05-2004 02:58 AM
Yes, thanks I am trying to use MRTG. I can't but Solarwinds.
