04-05-2005 01:48 AM - edited 03-02-2019 10:21 PM
I want make trunk mode between two switch (Catalyst 2950 and Catalyst 2924XL)
Here are the switchs configuration:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Cat2950
ip subnet-zero
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimise bpdu transmission
vlan2
name vlan2
interface FastEthernet0/1
switchport mode trunk
no ip address
interface FastEthernet0/2
switchport access vlan 2
switchport mode access
no ip address
spanning-tree portfast
...etc
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
no ip route-cache
ip http server
line con 0
line vty 5 15
end
version 12.0
no service pad
hostname Cat2924
ip subnet-zero
...etc
interface Vlan1
no ip directed-broadcast
no ip route-cache
shutdown
interface Vlan2
ip address 192.168.1.2 255.255.255.0
no ip route-cache
line con 0
transport input none
stopbits 1
line vty 5 15
end
then I verify the interface status ("show interfaces fa 0/1 switchport")
in 2924 operational mode is trunk but in 2950 operational mode is down
I don't understand why?
thx you in advance
04-05-2005 02:03 AM
If the two switches are connected over a cat5 cable, did you use a crosscable?
hth
paul
04-05-2005 04:47 AM
thx paul, I hadn't thought of that :)
