01-30-2003 09:54 PM - edited 03-02-2019 04:42 AM
Hello friend,
Two sites conneted via PSTN using sync modems. I am able to ping across for 20 seconds after i reboot the routers and the sync modem. After 20 seconds ping times out. Any troubleshooting tips would be highly appreciated. Here is the config of one of the router's interfaces connected to the sync modem.
interface Serial0
ip address 10.52.1.1 255.255.0.0
no ip directed-broadcast
encapsulation ppp
bandwidth 33
dialer in-band
dialer-group 1
no fair-queue
compress stac
ppp authentication chap
ppp chap hostname xxx
ppp chap password 7 xxx
pulse-time 1
01-30-2003 10:47 PM
What is your clocking source?
Are the devices well synchronized to this clock?
Did you try to switch off keep-alives? Please do so (int s0, no keep)
01-31-2003 06:07 AM
Tried that no +ve results.
01-31-2003 06:49 AM
When you have no result switching off keep-alives it is almost certain that you have a clocking problem. So I post my first question once again: How did you verify that your clocking is in order?
Normally, the network provides clocking to the modems. I presume that in your situation this will not be the case. Did you configure one modem as clock source? The other one will then have to derive its clock from this signal. Please investigate this issue.
