Join Customer Connection to register!
1051
p3systemsinc
Beginner
Two WS-X6148's with even/odd port failure?
Hello All,
First time on the forum, and I'm no Cisco expert (college co-op, actually) so my apologies if this is a humorously simple or misplaced post.
I have two WS-X6148-45AF linecards here that have been out of use for quite some time.
Upon inserting them in one of our 6509-E's I noticed that both had "Minor Error"s on their module diagnostics.
I would have just assumed that the cards were dead and requested replacements, but both cards have the *exact* same diagnostic errors, which only seem to effect every-other port. That's too much of a coincidence for me, so I figured I'd ask on the forums and see if I'm just missing something obvious before I assume the worst. Are these cards both somehow damaged in the exact same way? Or is there some config/compatibility issue that I haven't heard of?
relevant diagnostic output from one of the cards (Both outputs the same, no use posting twice) is below:
Router#show diagnostic result module 4
Current bootup diagnostic level: minimal
Module 4: 48-port 10/100 mb RJ45  SerialNo : SAL11391VUY
Overall Diagnostic Result for Module 4 : MINOR ERROR
Diagnostic level at card bootup: minimal
Test results: (. = Pass, F = Fail, U = Untested)
1) TestLoopback:
Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
F  .  F  .  F  .  F  .  F  .  F  .  F  .  F  .  .  F  .  F  .  F  .  F
Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
.  F  .  F  .  F  .  F  .  F  .  F  .  F  .  F  .  F  .  F  .  F  .  F
I have tried:
-Dusting the cards off
-Making sure the backplane connectors are not obviously damaged
-Using the cards in different slots
-Using the cards in different chassis
-Using the cards with different supervisors (though all were 720-3B's, and all the chassis were 6509-E's)
The diagnostic failures always come up the same, and are always identical. Again, two identical hardware failures seems a little too coincidental for me.
Any input would be greatly appreciated!
Dave G.
5 REPLIES 5
Leo Laohoo
VIP Community Legend
Run a disruptive diagnostics.
In enable mode, the command should be "diagnostic" and so-on.  My apologies, I don't have a 6500E handy at home right now.
Thanks for the quick reply - output of show diagnostic result after "diagnostic start module 4 test all" was run:
Module 4: 48-port 10/100 mb RJ45  SerialNo : XXXXXXXXXX
    1) TestLoopback:
    2) TestNetflowInlineRewrite:
         F  F  F  F  F  F  F  F  F  F  F  F  F  F  F  F  F  F  F  F  F  F  F  F
    3) TestEobcStressPing --------------> .
    4) TestFirmwareDiagStatus ----------> .
    5) TestAsicSync --------------------> .
    6) TestUnusedPortLoopback:
         U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U
    7) TestErrorCounterMonitor ---------> U
    8) TestPortTxMonitoring:
    9) TestVDB -------------------------> .
Let me know if you need anything more - though I will be leaving the office for the evening in a few.
Thanks again for your time!
Like I said, run a DISRUPTIVE diagnostics.  The command should start with "diagnostics" and you have to specify the module and the level of diagnostics.
What is your IOS and have you tried to re-seat the line card?
Have you tried moving the line card to a different slot?
I have already tried the following:
Current IOS version looks like "s72033_rp-ADVENTERPRISEK9_WAN-M"
As for the disruptive tests, correct me if I'm wrong:
Disruptive tests are indicated on the test ID list with attribute indicator "D"
Router#diagnostic start module 4 test ?
{..omitted..}
all             Select all test ID
  complete        Select the Complete bootup test suite [Attribute = C]
  minimal         Select the Minimal bootup test suite [Attribute = M]
  non-disruptive  Select the Non-Disruptive test suite [Attribute = N]
  per-port        Select the Per-Port test suite [Attribute = P]
So running "diagnostic start module 4 test all" should run disruptive diagnostics, which is what I ran prior to posting my last "show diagnostic result module 4" output.
As far as I know, there is no way to specify a disgnostic with option "disruptive".
I am currently running a "diagnostic start system test all", to see if that turns up anything else - this is the closest thing to a truly disruptive diagnostic that I can think of.
Thanks again, sorry if I got any of my lingo wrong.
"all" option is disruptive.   Wierd because you have some results as "U" which is un-tested.
Looks like it's time for you to RMA both cards.  The diagnostics result looks pretty bad.
Can you post the "sh version"?
Content for Community-Ad
