fasi74
Beginner
using my first cisco switch ..
Well i ordered a used cisco 1900 switch on ebay , the switch arrived , all ports are working , i didnt get a cable with it , so i got my old modem cable put the serial connector in my console port in switch & the other side in my LPT printer port in my PC, then i setup hyperterminal as instructed in my cisco book baurd rate etc etc ..
but i am not able to connect to the console i get a blank screen nothing else .. what am i doing wrong ? this is my first time , that y excited .. & wana make it work asap...
can you help me out here ?
thanks
5 REPLIES 5
glen.grant
Advisor
You are going to need a null cable to get that working , the 1900's were different than all other cisco switches as far as connecting into them . Or you can go to radio shack and get a null adaptor to fit your serial adaptor with a straight thru cable. Also if you have internet access download Tera Term for your terminal emulator , you'll have a lot less problems than trying to get hyperterm working correctly and it's also a real good telnet client .
I thought, most 1900s did have a RJ45 port on it, unless yours is a very old model. What kind of switch is it. There should be sticker on the back or side, 1912, 1924 ?
http://www.cisco.com/univercd/cc/td/doc/product/lan/28201900/1928v8x/19ja5107.htm
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
its a wc-c1900 switch , no i dont have a rj45 connector in the back the console port is a serial port ..
sir is it possible if you can show a picture of the cable on the internet here ? give me link .
i think the cable i have is also a null cable .. just wana be sure ..
thanks
Please see the pinouts for the null modem cable. You can make at on your own.
http://www.cisco.com/univercd/cc/td/doc/product/lan/28201900/1928v5x/rn5x/78363301.htm
http://www.stonewallcable.com/product.asp?dept%5Fid=114&pf%5Fid=SC%2D7319+++++++++++++\
-amit singh
