Community Helping Community
245
Beginner
VLAN communication between 4507 and 3845
I'm unable to ping vlans between the 4507 and the 3845. Here are the configs:
4507 CONFIG:
interface Vlan3
description Link to Subnet 1
ip address 10.7.129.50 255.255.255.0
ip helper-address 131.68.9.45
no ip redirects
ip pim sparse-mode
ip cgmp
arp timeout 234000
interface Vlan5
description User_VLAN
ip address 10.7.130.50 255.255.255.0
no ip redirects
ip pim sparse-mode
ip cgmp
shutdown
arp timeout 234000
interface Vlan30
description VTC_VLAN
ip address 10.4.58.50 255.255.255.0
no ip redirects
ip pim sparse-mode
ip cgmp
interface Vlan50
description WAN_ACCESS_VLAN
ip address 10.4.61.50 255.255.255.0
no ip redirects
ip pim sparse-mode
ip cgmp
interface Vlan100
description Management_VLAN
ip address 10.4.57.50 255.255.255.0
no ip redirects
ip pim sparse-mode
ip cgmp
router ospf 100
router-id 10.7.1.50
log-adjacency-changes
area 0 range 10.4.248.0 255.255.248.0
area 7 range 10.7.0.0 255.255.0.0
area 7 range 10.7.128.0 255.255.255.0
area 7 range 10.7.129.0 255.255.255.0
area 7 range 10.4.56.0 255.255.248.0
passive-interface Vlan100
network 10.7.0.0 0.0.255.255 area 7
network 10.7.128.0 0.0.31.255 area 7
network 10.8.96.0 0.0.31.255 area 0
network 10.8.253.0 0.0.0.255 area 0
network 10.4.56.0 0.0.7.255 area 7
network 10.4.248.0 0.0.7.255 area 0
default-metric 110
3845 CONFIG:
interface Loopback0
ip address 10.7.1.2 255.255.255.0
ip pim sparse-mode
interface Multilink1
ip address 10.7.159.9 255.255.255.252
ip pim sparse-mode
ppp multilink
ppp multilink group 1
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
description Link to 4507_CR_B G1/1
no ip address
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.50
description WAN_Access_VLAN
encapsulation dot1Q 50
ip address 10.4.61.2 255.255.255.0
no ip redirects
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.51
description Area_0_VLAN
encapsulation dot1Q 51
ip address 10.4.250.238 255.255.255.252
no ip redirects
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 10.4.57.2 255.255.255.0
no ip redirects
no ip route-cache
no ip mroute-cache
interface Serial0/0/0
ip address 10.4.250.98 255.255.255.252
interface Serial0/1/0
no ip address
interface Serial1/0
no ip address
dsu bandwidth 44210
interface Serial3/0
dsu bandwidth 44210
router ospf 100
router-id 10.7.1.3
default-metric 110
3 REPLIES 3
Collaborator
Re: VLAN communication between 4507 and 3845
where's the trunk configuration for the 4507??
you'll need a dot1q trunk that can carry the vlans you want to communicate between the two devices.
see the following link for more info:
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_book09186a00801d08aa.html
Beginner
Sorry, I didn't include that part.
4507:
interface GigabitEthernet3/1
description LINK TO 3845
switchport access vlan 50
switchport mode trunk
Collaborator
Try on the 4507:
showinter gig 3/1 switchport >> Looking for what the native vlan is, should be vlan 1.
On the router try:
conf t
interface gig 0/1.1
encapsulation dot1Q 1 native
Then try pinging from 4507 to the following ip addresses:
10.4.61.2
10.4.57.2
These are the only two interfaces that you should be above to ping since you do not have vlan 51 on 4507.
Please rate all posts
Content for Community-Ad
FusionCharts will render here
