Highlighted
Beginner
voice traffic priority and load balancing on two serial links
Hi..
I have two point to point serial links from different service providers on the router. My outgoing traffic is data and voice. For load balancing we have configured eigrp on the router but by configuring this my voice traffic is breaking because of link delay problem.
My requirement is to load balance the traffic and to give priority to the voice traffic to improve the voice quality.
Please let me know how to achive.
5 REPLIES 5
Highlighted
Advisor
Configure ppp multilink, on the links, (add them into a multilink group), and configure MLPPP fragmentation/ interleaving. This will help prevent, large data packets from causing delay to smaller voice packets. In addition to this, you can configure LLQ on the links, to give priority, as well as guaranteed bandwidth to voice traffic. Because PPP multilink is enabled, load balancing is taken care of...
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Highlighted
Just wanted to add that if one serial link fluctuates, the voice traffic is badly affected, I have experienced this a lot.In such cases do u manually shut down the link?
Praful
Highlighted
When a serial link flaps, the link is automatically removed from the bundle, and the rest of the serial interfaces, in the bundle will share the traffic. If you have only two links, and one flaps, all voice traffic has to share the bandwidth, and hence the bad quality.
Sankar Nair
Highlighted
Hi..
Incase if i cann't configure multilink what is the otherway to improve voice traffic with eigrp routing enable between two links.
Configuration of Multilink is not possible because of other end customer issue. If is there any other way it will be very helpful to me.
Jatin
Highlighted
you could try to configure CBWFQ in conjunction with ip rtp priority on both serial links. This way, even if there is only one link active, voice traffic will still be prioritized. Here is a config example from CCO:
The following example first defines a CBWFQ configuration and then reserves a strict priority queue with the following values: a starting RTP port number of 16384, a range of 16383 UDP ports, and a maximum bandwidth of 40 kbps:
! The following commands define a class map:
class-map class1
match access-group 101
exit
! The following commands create and attach a policy map:
policy-map policy1
class class1
bandwidth 3000
queue-limit 30
random-detect
random-detect precedence 0 32 256 100
exit
interface Serial1
service-policy output policy1
! The following command reserves a strict priority queue:
ip rtp priority 16384 16383 40
Georg
Content for Community-Ad
