What is the difference between C6509 and C6509-E chassi?
seungmin Lee
sean_evershed
Level 7
Level 7
The 6509 is end of sale:
http://www.cisco.com/en/US/products/hw/switches/ps708/ps711/index.html
It could only support a maximum of a 4000W power supply.
The 6509E supports in excess of 6000W power supplies.
It also supports the newer technology such as the Sup 2T and the ASA blades.
Cheers
Sean
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
As Sean has noted, one of the features that -E chassis supports is newer technology blades, i.e. the -E supports up to 80 Gbps per slot, including all the slots of a 6513-E.
Mohamed Sobair
Level 7
Level 7
In Addition to the Switching Capacity and BW per Slot, Power Supply,  Note, You Cant run the VSS Feature on the Normal 6000 Series Chasis. You should have the E Series of the Catalyst 6000 Chasis.
Mohamed
