what is the difference between (ip ssh maxstartups 5) and (vty 0 4)
Sudqi
what is the difference between (ip ssh maxstartups 5) and (vty 0 4), as i know vty 0 4 is to make 5 users connect to the device in the same time, but what is the needed for (ip ssh maxstartups)?
5 Replies 5
luis_cordova
Hi @Sudqi
The line vty 0 4 command allows you to access the line configuration mode, where you can enter the parameters for those 5 vty lines.
You must keep in mind that more than 5 lines can be enabled on the devices.
The ip ssh maxstartups [number] command allows you to limit the number of simultaneous connections per SSH
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/security/d1/sec-d1-cr-book/sec-cr-i3.html#wp3414043258
thank you Iuis for the reply
"You must keep in mind that more than 5 lines can be enabled on the devices"
i doesn't understand this sentence, what is the lines used for?
Hi @Sudqi
I meant that in many cisco devices you can enable more than 5 vty lines, for example, with the command line vty 0 15, where you can configure the parameters for 16 vty lines.
https://community.cisco.com/t5/other-network-architecture/how-many-vty-lines-are-there/td-p/176783
@luis_cordova
but maxstartups  up to 128 !
Hi @Sudqi
That's right.
In fact, there are versions of IOS that allow many more vty lines.
Check out this community discussion:
https://community.cisco.com/t5/firewalls/best-practices-for-securing-vty-lines/td-p/2105377
