03-30-2005 07:51 AM - edited 03-02-2019 10:18 PM
Hello,friends:
I am a chinese man,so please forget my pool english first!I have two servers and there are two jboss servers on each one servers.I use LD 430 to load balancing.The before configuation is below:
lb(config)# show config
hostname lb
no shutdown ethernet 0
no shutdown ethernet 1
no shutdown ethernet 2
no shutdown ethernet 3
interface ethernet 0 auto
interface ethernet 1 auto
interface ethernet 2 auto
interface ethernet 3 10baset
mtu 0 1500
mtu 1 1500
mtu 2 1500
mtu 3 1500
multiring all
no secure 0
no secure 1
no secure 2
no secure 3
ping-allow 0
ping-allow 1
ping-allow 2
ping-allow 3
ip address 10.0.0.2 255.255.255.0
route 0.0.0.0 0.0.0.0 10.0.0.1 1
arp timeout 30
no rip passive
rip version 1
failover ip address 0.0.0.0
no failover
failover hellotime 30
password xxxx
telnet 218.x.x.x.255.255.0
telnet 10.0.0.0 255.255.255.0
telnet 211.x.x.255.255.0
no snmp-server enable traps
snmp-server community public
no snmp-server contact
no snmp-server location
tftp-server 192.168.1.41 port 69 conf
virtual 10.0.0.205:80:0:tcp is
virtual 10.0.0.205:8080:0:tcp is
real 10.0.0.101:8081:0:tcp is
real 10.0.0.100:8081:0:tcp is
real 10.0.0.101:8080:0:tcp is
real 10.0.0.100:8080:0:tcp is
name 10.0.0.101 server2
name 10.0.0.100 server1
name 10.0.0.205 vserver
no names
bind 10.0.0.205:80:0:tcp 10.0.0.100:8080:0:tcp
bind 10.0.0.205:80:0:tcp 10.0.0.100:8081:0:tcp
bind 10.0.0.205:80:0:tcp 10.0.0.101:8080:0:tcp
bind 10.0.0.205:8080:0:tcp 10.0.0.101:8081:0:tcp
bind 10.0.0.205:8080:0:tcp 10.0.0.100:8080:0:tcp
bind 10.0.0.205:8080:0:tcp 10.0.0.101:8080:0:tcp
bind 10.0.0.205:8080:0:tcp 10.0.0.100:8081:0:tcp
probeconfig http 3.
It works well.
But now I want add a virtual IP 10.0.0.205:9090 to bind 10.0.0.100:8080,so I can access the service on the port 9090 on website.so I config again,but the virtual can not work,that means that I can not access the website on port 9090.What is wrong with the virtual IP?,the current configuation is below:
hostname lb
mtu 0 1500
mtu 1 1500
mtu 2 1500
mtu 3 1500
multiring all
no secure 0
no secure 1
no secure 2
no secure 3
ping-allow 0
ping-allow 1
ping-allow 2
ping-allow 3
arp timeout 30
no rip passive
rip version 1
no failover
password xxx
telnet 211.x.x.x.255.255.0
virtual 10.0.0.205:9090:0:tcp is
predictor 10.0.0.205:9090:0:tcp leastconns none
replicate 10.0.0.205:9090:0:tcp
no names
bind 10.0.0.205:9090:0:tcp 10.0.0.100:8080:0:tcp
probeconfig http 3
03-31-2005 11:59 AM
Try adding the following
real 10.0.0.100:9090:0:tcp is
bind 10.0.0.205:9090:0:tcp 10.0.0.100:9090:0:tcp
If I understand your problem your LD is NAT the port from 9090 to 8080.
Mike
