WRED and DSCP configuration
yuan
I have this question regarding the following QoS configuration on a policing router (assuming dscp marking has already been done by a different router),
class-map match-any video
match ip dscp af41
match ip dscp af42
policy-map qos
class video
bandwidth 20
random-detect dscp-based
interface serial0/0
service-policy qos
my question is, does this configuration mean although packets that are marked "af41" and "af31" are sharing the same bandwidth of 20%, when congestion happens, packets marked with af42 will have a higher probability of being dropped than af41?
dgahm
Level 8
Level 8
Yes, the defaults for AF41 would mean that when there are between 32 and 40 AF41 packets queued, 1 out of 10 would be discarded. Over 40 they all would be discarded. For AF42 the minimum threshold is 28 with the max 40, and the same probability of 1/10.
You can change this:
random-detect dscp AF42 10 30 5
This would discard 1 out of 5 packets when the queue depth is between 10 and 30.
dgahm
Level 8
Level 8
