01-02-2014 09:43 PM - edited 03-03-2019 07:15 AM
According to CISCO, the image is compatiple with WS-C3750X-24P-S however the switch just fails to boot with it.
Here is the error below:
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
The switch is not booting from USB stick either. The only image that works is c3750e-universalk9-mz.122-55.SE3.bin.
If I copy this file to flash, the switch fail over to it. The console's output below (I replaced some lines with <...>):
Switch#dir flash:
Directory of flash:/
2 -rwx 14587929 Mar 1 1993 00:19:08 +00:00 c3750e-universalk9-mz.122-55.SE3.bin
3 -rwx 23356416 Jan 1 1970 00:18:53 +00:00 c3750e-universalk9-mz.152-1.E1.bin
4 -rwx 3853 Mar 1 1993 00:05:58 +00:00 private-config.text
6 -rwx 3096 Mar 1 1993 00:05:58 +00:00 multiple-fs
7 -rwx 1747 Mar 1 1993 00:05:58 +00:00 config.text
57671680 bytes total (19408384 bytes free)
Switch#verify /md5 flash:/c3750e-universalk9-mz.152-1.E1.bin
verify /md5 (flash:/c3750e-universalk9-mz.152-1.E1.bin) = 9332aa4e055bfb9fbeba677ecd83e9a6
Switch#show boot
BOOT path-list : flash:/c3750e-universalk9-mz.152-1.E1.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
NVRAM/Config file
buffer size: 524288
Timeout for Config
Download: 0 seconds
Config Download
via DHCP: disabled (next boot: disabled)
Switch#reload
Proceed with reload? [confirm]
*Mar 2 04:49:34.795: %SYS-5-RELOAD: Reload requested by console. Reload reason: Reload command
Using driver version 3 for media type 2
Base ethernet MAC Address: e4:d3:f1:12:9c:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
...done Initializing Flash.
done.
Loading "flash:/c3750e-universalk9-mz.152-1.E1.bin"...@@@<...>
File "flash:/c3750e-universalk9-mz.152-1.E1.bin" uncompressed and installed, entry point: 0x3000
executing...
Loading "flash:/c3750e-universalk9-mz.122-55.SE3.bin"...@@@<...>
File "flash:/c3750e-universalk9-mz.122-55.SE3.bin" uncompressed and installed, entry point: 0x3000
executing...
cisco WS-C3750X-24P (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1503R1RU
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : E4:D3:F1:12:9C:00
Motherboard assembly number : 73-12551-06
Motherboard serial number : FDO16381003
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C3750X-24P-S
Daughterboard assembly number : 800-32727-03
Daughterboard serial number : FDO16380YYA
System serial number : FDO1503R1RU
Top Assembly Part Number : 800-31325-03
Top Assembly Revision Number : B0
Version ID : V03
CLEI Code Number : COMJR00ARC
Hardware Board Revision Number : 0x04
3480560K bytes of USB Flash usbflash0 (Read/Write)
Switch Ports Model SW Version SW Image
* 1 30 WS-C3750X-24P 12.2(55)SE3 C3750E-UNIVERSALK9-M
Press RETURN to get started!
Is it something that can be fixed?
01-13-2014 09:24 PM
Hmm..
Here is an output from standard serial connection (Baud rate:9600/Data:8/Parity:None/Stop:1/Flow Control:None) :
switch: set
5@=±ÖD ©„bïNûÇóþÚÓJ5í'혂Œ·· ~6ÂÂE“_äŠ~}µOÇw¯þ,ÀdF^ûÍ¿—SkZy_7þ(žv(A?ÂcyÞc¥ÝÔmZ™:{}ä1;¾öŒ©©v«Òß0ÿxw#àlÚ¥&°Ü?&…;‹ä8ó~cI?'‰òJŠ¤DÞBBEP±*ô°âëà ž@È)J€7á,]ôªVºû4²Û¼ìåÜÑA@R»²5ž[Yç—Ã
BAUT=38400
BOARD_CONFIG_REV=0
BOOT=flash:/c3750e-universalk9-mz.150-2.SE5/c3750e-universalk9-mz.150-2.SE5.bin
CLEI_CODE_NUMBER=COMJR00ARC
DAUGHTERBOARD_ASSEMBLY_NUM=800-32727-03
DAUGHTERBOARD_SERIAL_NUM=FDO16380YYA
DEFAULT_ROUTER=10.11.164.1
IP_ADDR=10.11.166.8/255.255.252.0
MAC_ADDR=E4:D3:F1:12:9C:00
MODEL_NUM=WS-C3750X-24P-S
MODEL_REVISION_NUM=A0
MOTHERBOARD_ASSEMBLY_NUM=73-12551-06
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FDO16381003
SDM_TEMPLATE_ID=0
SWITCH_NUMBER=1
SWITCH_PRIORITY=1
SYSTEM_SERIAL_NUM=FDO1503R1RU
TAN_NUM=800-31325-03
TAN_REVISION_NUMBER=B0
-- MORE --
The="IP_ADDR
UNBAUD=
VERSION_ID=V03
default_router=10.11.164.1
netmask=255.255.252.0
01-14-2014 12:47 AM
I give up!
I can't see anything which points to the cause.
The only stupid thing I can think of is that your appliance could be a counterfiet. And that's a wild accusation I can't back up.
If no one else has any ideas, I recommend Oleg you create a TAC Case.
01-14-2014 01:25 PM
Thank you Leo! I will contact the vendor that sold us the unit soon.
I don't think it is normal to have these random characters immediatelly after the SET command. It looks like the ROM is damaged.
01-14-2014 01:29 PM
Agree.
01-11-2014 09:01 AM
Hi Oleg,
Can you try upgrading to any IOS first in between 12.2(55)SE3 and 15.2(1)E1 and then upgrade it to 15.2(1)E1. ? This means lets first upgrade the IOS to a pre latest image and then finally to 15.2(1)E1.
Generally we do not need intermediate upgrade but as it is not an expected behavior, we can give it a try.
Please rate helpful post. Thanks.
