# show chassis environment detail Chassis 1: Overall Status: Operable Operability: Operable Power State: Ok Thermal Status: Ok
Cisco Firepower Extensible Operating System (FX-OS) Software
# show system version FPRM: Running-Vers: 4.3(1.74) Package-Vers: 2.3(1.56) Activate-Status: Ready
This is what you looking for i guess :
Hi Balaji,
Thanks for the reply. Yes, I think a subset of those is what I'd need. Does the following indicate that I have to have someone enable these MIBs on the device or am I attempting to query this information incorrectly? I appreciate the assistance.
$ snmpwalk -v2c -c ${COMMUNITY} ${DEVICE} CISCO-FIREPOWER-POWER-MIB No log handling enabled - turning on stderr logging CISCO-FIREPOWER-POWER-MIB: Unknown Object Identifier (Sub-id not found: (top) -> CISCO-FIREPOWER-POWER-MIB)
Before loading FXOS MIBs into an NMS, you must first load the prerequisite MIBs into the NMS. This enables you to receive the FXOS Fault Traps in the NMS.
