Beginner
Netconf XPATH - multicast (PIM, IGMP)
Hi there,
Trying to get some config and oper data via Netconf using XPATH based filters for multicast elements - IGMP, PIM, mroute tables etc.
I can't figure out the xpath into multicast ... trying getting the tree using pyang against the cisco provided .yang files ... gets me nowhere. (ex. Cisco-IOS-XE-multicast.yang, Cisco-IOS-XE-igmp.yang)
Anyone using XPATH based filters for netconf get ... ?
Thank you,
Mihai
Everyone's tags (1)
4 REPLIES 4
Re: Netconf XPATH - multicast (PIM, IGMP)
Beginner
Not really … it has the xpath example for hostname, I know how to script the get operations for netconf etc.
What I can’t figure out is how to build the XPATH filters for multicast …
Thx.
Ps: here is a snippet of my script
netconf_reply=m.get(filter=('xpath','/ip/multicast'))
print ("#" * 80)
#netconf_reply=m.get(filter=('xpath',netconf_filter))
#netconf_reply = m.get(filter=('xpath','/interfaces-state/interface[name='GigabitEthernet1']/oper-status'))
# /if:interfaces-state/if:interface/if:oper-status
# /bgp-state-data/neighbors/neighbor/session-state
# /bgp-state-data/neighbors/neighbor[neighbor-id="10.10.33.2"]/prefix-activity/received/current-prefixes
# /bgp-state-data/bgp-route-vrfs/bgp-route-vrf[vrf="default"]/bgp-route-afs/bgp-route-af[afi-safi="ipv4-unicast"]/bgp-route-neighbors/bgp-route-neighbor[nbr-id="10.10.33.2"]/bgp-neighbor-route-filters/bgp-neighbor-route-filter[nbr-fltr="bgp-nrf-post-received"]/bgp-neighbor-route-entries/bgp-neighbor-route-entry/prefix
# /bgp-state-data/bgp-route-vrfs/bgp-route-vrf[vrf="default"]/bgp-route-afs/bgp-route-af[afi-safi="ipv4-unicast"]/bgp-route-filters/bgp-route-filter[route-filter="bgp-rf-all"]/bgp-route-entries/bgp-route-entry/available-paths
# /bgp-state-data/bgp-route-vrfs/bgp-route-vrf[vrf="default"]/bgp-route-afs/bgp-route-af[afi-safi="ipv4-unicast"]/bgp-route-filters/bgp-route-filter[route-filter="bgp-rf-all"]/bgp-route-entries/bgp-route-entry[prefix="8.8.81.0/24"]/bgp-path-entries/bgp-path-entry/weight
# /bgp-state-data/bgp-route-vrfs/bgp-route-vrf/bgp-route-afs/bgp-route-af/bgp-route-filters/bgp-route-filter/bgp-route-entries/bgp-route-entry/bgp-path-entries/bgp-path-entry/as-path
# /bgp-state-data/bgp-route-vrfs/bgp-route-vrf[vrf="default"]/bgp-route-afs/bgp-route-af[afi-safi="ipv4-unicast"]/bgp-route-filters/bgp-route-filter[route-filter="bgp-rf-all"]/bgp-route-entries//bgp-route-entry[prefix="4.4.5.0/24"]/bgp-path-entries/bgp-path-entry[nexthop="10.10.25.5"]/path-status/bestpath'))
#print(netconf_reply)
# Process the XML and store in useful dictionaries
#nr = xmltodict.parse(netconf_reply.xml)["rpc-reply"]["data"]["bgp-state-data"]["bgp-route-vrfs"]
pp.pprint(nr)
#pprint.pprint(nr["bgp-state-data"]["bgp-route-vrfs"]["bgp-route-afs"])
#print ("=" * 80)
#print (type(nr))
#print ("findkey=",findkey(nr,'ospf-neighbor'))
Highlighted
Is something like this you are trying to get ?
xmlDom = xml.dom.minidom.parseString( str( m.get_config( source='running', filter=('xpath', 'native/ip/multicast'))))
<?xml version="1.0" ?>
<rpc-reply message-id="urn:uuid:a9e323f3-c028-11e8-8524-8c8590ab85a6" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0">
  <data>
    <native xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-native">
      <ip>
        <multicast>
          <multipath xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-multicast"/>
        </multicast>
      </ip>
    </native>
  </data>
</rpc-reply>
Beginner
Here is an example of XPATH filter used to retrieve ipv4 unicast …. Trying to figure out the XPATH filter to retrieve let’s say the mcast route table ☺
Thank you.
netconf_reply=m.get(filter=('xpath','/routing-state/routing-instance[name="default"]/ribs/rib/routes'))
(nap) C02WX141HTD5:Cisco mihaiiancu$ python ncc0.py
OrderedDict([('routing-state',
OrderedDict([('@xmlns',
'urn:ietf:params:xml:ns:yang:ietf-routing'),
('routing-instance',
OrderedDict([('name', 'default'),
('ribs',
OrderedDict([('rib',
[OrderedDict([('name',
'ipv4-default'),
('routes',
OrderedDict([('route',
[OrderedDict([('destination-prefix',
'0.0.0.0'),
('route-preference',
'1'),
('metric',
'1'),
('next-hop',
OrderedDict([('outgoing-interface',
None),
('next-hop-address',
'10.173.124.1')])),
('source-protocol',
'static'),
('active',
None)]),
'1.1.121.0'),
'110'),
('metric',
'110'),
('next-hop',
'GigabitEthernet2.121'),
'10.10.12.5')])),
('source-protocol',
OrderedDict([('@xmlns:ospf',
'urn:ietf:params:xml:ns:yang:ietf-ospf'),
('#text',
'ospf:ospfv2')])),
('active',
None)]),
'3.3.0.0'),
'20'),
('metric',
'20'),
('next-hop',
None),
'10.10.33.3')])),
('source-protocol',
OrderedDict([('@xmlns:rt-ext',
'urn:cisco:params:xml:ns:yang:cisco-routing-ext'),
('#text',
'rt-ext:bgp')])),
('active',
None)]),
'3.3.1.0'),
'200'),
('metric',
'200'),
('next-hop',
None),
'10.10.12.1')])),
('source-protocol',
('#text',
'rt-ext:bgp')])),
('active',
None)]),
'3.3.2.0'),
'20'),
('metric',
'20'),
('next-hop',
None),
'10.10.33.3')])),
('source-protocol',
('#text',
'rt-ext:bgp')])),
('active',
None)]),
'3.3.3.0'),
'20'),
('metric',
'20'),
('next-hop',
None),
'10.10.33.3')])),
('source-protocol',
('#text',
'rt-ext:bgp')])),
('active',
None)]),
'4.4.1.0'),
'200'),
('metric',
'200'),
('next-hop',
None),
'10.10.12.1')])),
('source-protocol',
('#text',
'rt-ext:bgp')])),
('active',
None)]),
'4.4.2.0'),
'200'),
('metric',
'200'),
('next-hop',
None),
'10.10.12.1')])),
('source-protocol',
('#text',
'rt-ext:bgp')])),
('active',
None)]),
'4.4.3.0'),
'200'),
('metric',
'200'),
('next-hop',
None),
'10.10.12.1')])),
('source-protocol',
('#text',
'rt-ext:bgp')])),
('active',
None)]),
'4.4.5.0'),
'200'),
('metric',
'200'),
('next-hop',
None),
'10.10.12.1')])),
('source-protocol',
('#text',
'rt-ext:bgp')])),
('active',
None)]),
'4.4.8.0'),
'20'),
('metric',
'20'),
('next-hop',
None),
'10.10.25.5')])),
('source-protocol',
('#text',
'rt-ext:bgp')])),
('active',
None)]),
'8.8.8.0'),
'0'),
('metric',
'0'),
('next-hop',
'Loopback8'),
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'8.8.8.8'),
'0'),
('metric',
'0'),
('next-hop',
'Loopback8'),
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'8.8.81.0'),
'0'),
('metric',
'0'),
('next-hop',
'Loopback81'),
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'8.8.81.81'),
'0'),
('metric',
'0'),
('next-hop',
'Loopback81'),
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'10.10.12.0'),
'0'),
('metric',
'0'),
('next-hop',
'GigabitEthernet2.120'),
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'10.10.12.2'),
'0'),
('metric',
'0'),
('next-hop',
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'10.10.12.4'),
'0'),
('metric',
'0'),
('next-hop',
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'10.10.12.6'),
'0'),
('metric',
'0'),
('next-hop',
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'10.10.13.4'),
'110'),
('metric',
'110'),
('next-hop',
'10.10.12.5')])),
('source-protocol',
('#text',
'ospf:ospfv2')])),
('active',
None)]),
'10.10.25.0'),
'0'),
('metric',
'0'),
('next-hop',
'GigabitEthernet4'),
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'10.10.25.2'),
'0'),
('metric',
'0'),
('next-hop',
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'10.10.33.0'),
'0'),
('metric',
'0'),
('next-hop',
'GigabitEthernet3'),
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'10.10.33.2'),
'0'),
('metric',
'0'),
('next-hop',
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'10.173.124.0'),
'0'),
('metric',
'0'),
('next-hop',
'GigabitEthernet1'),
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)]),
'10.173.124.219'),
'0'),
('metric',
'0'),
('next-hop',
'0.0.0.0')])),
('source-protocol',
'direct'),
('active',
None)])])]))]),
'ipv6-default')])])]))]))]))])
R2
Content for Community-Ad
August's Community Spotlight Awards
