01-23-2003 03:13 AM - edited 03-09-2019 01:48 AM
Is it possible to apply two crypto maps to the same interface in a router ?I have two crypto maps because I need to use two different authentication methods depending on the VPN client that is going to connect.
Solved! Go to Solution.
01-23-2003 06:43 PM
No, you can only have one crypto map per interface.
01-23-2003 06:43 PM
