4235 Can it use a Quad card
dedube23
Beginner
Beginner
Hello All I am in the process of odering IDS units that we will need for work and was wondering if the 4235 IDs unit can support the Quad card. I ask this because I want to have a interface on every DMZ we have with our PIX. Any ideas or thoughts on this. WE will be terminating a VPN concentrator. Client and parterner VPNS web farm etc. Bandwidth could potentialy grow over 80 Mbs potentially with the termintation remote sites up to 50 -100 vpn connections.
Has anyone used the Ciscoworks SIM yet. Is it exactly like the Netoforesnic unit. Has anyone used the all in one unit. Let me know the results.
David
bkubesh
Beginner
Beginner
The 4235 can currently support the Intel Quad FE card. Are you referring to quad FE or quad GE card?
-Blaine
I was referring to the FE card.
Do you know if the SIM applance is out yet.
Recognize Your Peers
