Highlighted
Beginner
501 will not NAT using zoneedit
I have a 501 in front of my soho. It's runnig 6.2(2) I'm using cable modem and it gives my outside interface an IP dynamically. I use the "zoneedit" free dynamic DNS. This service will always point my web site to the correct IP, so it should allow me to host a web site on a server behind the PIX. I added the following 3 rules:
access-list inbound permit tcp any host xxx.xxx.xxx.xxx eq www
access-group inbound in interface outside
static (inside,outside) xxx.xxx.xxx.xxx 192.168.1.10 netmask 255.255.255.255 0 0
When I add the third rule,
I can no longer get out to the internet. It seems like I cannot nat.
Any ideas what I'm doing wrong.
5 REPLIES 5
Highlighted
Contributor
Re: 501 will not NAT using zoneedit
Hello Paul,
What you need to do is Port redirection here ..
no static (inside,outside) xxx.xxx.xxx.xxx 192.168.1.10 netmask 255.255.255.255
static (inside,outside) tcp xxx.xxx.xxx.xxx www 192.168.1.10 www netmask 255.255.255.255 0 0
If PIX doesn't accept the last line, please replace xxx.xxx.xxx.xxx with keyword "interface".
After that please execute "clear xlate" and you would be good to go.
Mynul
Highlighted
Beginner
Hi Mynul,
Thank you for replying. I added the rule above and the PIx took. I also cleared the xlate and still nothing.
Below is a copy of my config:
: Written by enable_15 at 20:53:25.310 EDT Wed Jul 2 2003
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password encrypted
passwd encrypted
hostname
domain-name
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list 101 permit tcp any host xx.xx.xxx.xx eq pptp
access-list 101 permit gre any host xx.xx.xxx.xx
pager lines 24
logging host inside 192.168.1.10
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.5 255.255.255.255 inside
pdm location 192.168.1.10 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp xx.xx.xxx.xx www 192.168.1.10 www netmask 255.255.25
5.255 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.1.5 255.255.255.255 inside
telnet 192.168.1.10 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.11-192.168.1.33 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxxxx
Thanks for you help
Highlighted
Beginner
Paul,
Try changing your static command to the following. This will force the use of
the global address of the Interface and resolve any overlapping address conflict .
static (inside,outside ) interface 192.168.1.10 netmask 255.255.255.255 0 0
Highlighted
Beginner
Paul,
Highlighted
Contributor
Hi Paul,
The above is going to override the global pool hence traffic from inside using PAT/global will have issue. Only host 192.168.1.10 would be able to go out.
Is x.x.x.x a routable ip address? is it same as outside interface ip address that you are getting dynamically? If its the same ip address as interface, please add the line with "interface" keyword as suggested in my earlier pool.
Mynul
