05-12-2016 12:32 AM - edited 02-20-2020 09:44 PM
I am trying to create ACL on Cisco router which will allow all traffic from inside to internet and only allow specific traffic from internet to inside.
This is what I've configured and puted on Router's interface connected to ISP:
So I can connect from my public IP to Customer's LAN via RDP and SSH (which is o.k.), but Customer's users can not Access Internet (which is not o.k.)!
Users are all in the same Vlan. Between Vlan interface and Outside interface (dialer 1) is PAT.
There are no other ALC on the router exept the one for PAT.
What am I missing here?
Thanks.
Solved! Go to Solution.
06-06-2016 10:32 AM
Great, thank you mate!
05-13-2016 03:13 AM
I would remove the access-group from dialer1; you will not be exposing the inside unnecessarily.
I wouldn't do it that way. There should always be a restrictive ACL configured.
First, NAT is not meant to protect the internal network. Although a good NAT implementation can help, it's the wrong tool for the right job. That is the job of a firewall. (You could also hammer a nail into the wall with an electric drill, but it's better to use the tool that was designed for the needed task).
And without an ACL you still expose the router itself to the outside world with all potential vulnerabilities. Again, the restrictive ACL makes sure to only expose the services you need.
05-12-2016 02:42 AM
What kind of router do you have? If you can run a firewall feature set, it would make the configuration much easier.
If supported, you could use the following config:
ip inspect name FW ftp
ip inspect name FW dns
ip inspect name FW icmp router-traffic
ip inspect name FW tcp router-traffic
ip inspect name FW udp router-traffic
ip access-list ext OUTSIDE-IN
deny ip any any
interface dialer 1
ip inspect FW out
ip access-group OUTSIDE-IN in
This config looks at (inspects) all traffic leaving to the ISP and automatically allows the return traffic. All other traffic is blocked.
05-12-2016 03:12 AM
Hello Karsten,
I also need to allow RDP, SSH from outside (from my company) to Customer's LAN.
Can I adjust ACL Outside-in like this:
permit tcp "my public IP" any eq 3389
permit tcp "my public IP" any eq 22
deny ip any any
Thnx, J
05-12-2016 03:34 AM
yes, you add all additionally needed service above the deny-rule. But typically you would also need a static translation which you don't have? I wonder why it was working ...
05-12-2016 03:39 AM
o.k.
If you are talking about NAT, I do have configuration for that.
J
05-12-2016 03:45 AM
ok, just thought that the below mentioned NAT-config was all that you have.
05-12-2016 03:52 AM
I have some static NAT statements for RDP.... just didn't post them...
I Will try with your suggestion, probablly I Will wait for replay from Seb (below) if he will have any other idea.
For sure, I will post the result.
Thank you,
J
05-13-2016 02:47 AM
this is what I've configured:
I've create ACL:
access-list 101 permit icmp any any
access-list 101 permit tcp "my public IP" any eq 3389
access-list 101 permit tcp "my public IP" any eq 22
access-list 101 permit udp any any eq ntp
access-list 101 deny ip any any
And configured Dialer 1:
ip access-group 101 in
ip inspect FW out
That's it. It is working. And I probably do not need "permit udp any any eq ntp" in ACL, because in FW rule is "ip inspect name FW udp router-traffic" ?
J
05-13-2016 03:06 AM
If this rule is meant to let NTP-answers back to the router, then yes, the inspection will take care of that.
05-13-2016 04:28 AM
I am not sure I get it right. I use public NTP servers and my router is syncing with them. So do I need :
or not?
05-13-2016 04:35 AM
No, you don't need that line. The NTP-request is sent out and gets inspected by the router. The NTP-answer matches a "state-entry" that the router has build by the inspection. Based on this state-entry the NTP-answer is allowed. The ACL is only used when new connections arrive at the public interface, that is the incoming SSH and RDP in your case.
05-13-2016 04:40 AM
Thanks, I understand.
Your advices were (are) really Helpfull.
J
