ACS authenticacion
agustinmar
Hello, it is possible that an ACS server authenticates with TACACS some clients and RADIUS other clients?
Thank you.
mattiaseriksson
Level 3
Level 3
Short answer: yes
But it also depends on the authentication protocol and features that you want to use. Network Access Profiles for example, only support Radius.
Hi ,
Yes ACS supports both Radius and Tacacs+ protocols. It can use both at a same time.
Let me know if you have any question.
~JG
