Any help is appriciated
khaile
I Pass 503,522 and 552 what else do I need to get CCSP sertification. thanks
Jon Marshall
Jon, I know that, the things is I did not see 522 any more what do you think about that. thanks anyway
My suggestion is to view the Cisco Certification Tracking System :
https://i7lp.integral7.com/durango/do/login?ownername=cisco&channel=cisco&basechannel=integral7
with your login and password, and see the status of your certifications, and the exams required in order to be certificated.
Another link, that may be helpful is Certification On line Support
http://ciscocert.custhelp.com/cgi-bin/ciscocert.cfg/php/enduser/std_alp.php
I hope this helps.
Best regards.
Massimiliano.
