Cisco Community Designated VIP Class of 2020
182
Beginner
ASA in transparent mode and IP addresses
I need to put an ASA in transparent mode.
Our router (managed by the carrier) routes more than one public IP class in a single VLAN.
On the "Cisco Security Appliance Command Line Configuration guide", in "Trasnaprent Firewall Guidelines" it's written: "Each directly connected network must be on the same network".
This means also that I can have ONLY ONE subnet that flows fron the outside and the inside, or can I have more than one class?
If I can have only one class, the only solution is to use multiple context (and separate each classes in different interfaces)?
Thanks a lot
3 REPLIES 3
Beginner
Re: ASA in transparent mode and IP addresses
No one can help me?
Thanks a lot.
Highlighted
Beginner
Auto answer: there is no limit on the number of IP classes that can flow through the ASA in transparent mode.
Thanks anyway.
Marco.
Beginner
The ASA in trasparent mode works at layer 2. So it really does not care if the traffic that flows through it is from different subnet as long as the L3 devices it connects to knows how to reach these subnet. TheASA in transparent is basically a bump in the wire (a bridge) and for that reason you can only use 2 interfaces on the ASA in transparent implementation.
P.S. When people see attitude in your threads, they will refrain from answering your question. That's for future reference.
Content for Community-Ad
FusionCharts will render here
