Ask the Expert- SD-WAN
242
Highlighted
Beginner
ASA5505: Policy Based Routing only possible if a routing protocol is enabled?
Hello everybody,
I have a ASA5505 running OS rel. 9.1(7)32.
Between this ASA and the target network are two different lines, one with encryption (S2S VPN) and one MPLS line.
Depending on the source IP network I need to route that packets defferently.
The packets comming from source network A need to go though the S2S tunnel terminated on this ASA and the rest of the traffic goes over the MPLS line.
On the ASA there are no routing protocols enabled because there are not may networks to handle.
Now I want to configure PBR as like in this example:
http://resources.intenseschool.com/policy-based-routing-on-the-cisco-asa/
but when I want to 'set ip next-hop <ip-addr>' I saw this is not possible:
ASA5505(config)#
ASA5505(config)# route-map PBR4Server permit 10
ASA5505(config-route-map)# match ip address DMZ2Server
ASA5505(config-route-map)# set ?
route-map mode commands/options:
metric Set metric value for destination routing protocol
metric-type Set type of metric for destination routing protocol
ASA5505(config-route-map)# set ip next-hop ?
ERROR: % Unrecognized command
My questions:
1. Is it possible to configure Policy Based Routing only possible if a routing protocol is enabled?
2. If this is the case: Is there any other possibility to route to a certain target depending on the source network the packets come from (without routing protocols)?
Every hint is very welcome!
Thanks a lot!
Greatings!
1 ACCEPTED SOLUTION
VIP Advisor
Re: ASA5505: Policy Based Routing only possible if a routing protocol is enabled?
PBR doesn't work on your asa 5505 because it requires version 9.4.1 minimum and this level of version isn't available for your device.
You can't achieve source based routing but playing around with nat could maybe help. Do you have a quick drawing to share? and your asa config?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
3 REPLIES 3
VIP Advisor
Francesco
Beginner
Hi Francesco,
thanks for your hint with the minimum version for PBR!
This helps me a lot!
Thanks a lot!
Greatings!
VIP Advisor
You're welcome
Francesco
