08-19-2005 03:17 PM - edited 03-09-2019 12:12 PM
Config:
interface Ethernet0/0
nameif outside
security-level 0
interface Ethernet0/1
nameif inside
security-level 100
Since some dedicated networks are connected to the inside LAN, this ASA has static routing (route inside x.x.x.x ...), and the inside is all clients' default gw.
Then I found incoming traffic can't be routed to next hops. I think PIX can't do this. Is this possible on ASA. Or do I need to some more settings?
TIA,
08-22-2005 12:43 PM
Let me follow up,
nameif outside
security-level 0
ip address 1.1.1.2 255.255.255.0
nameif inside
security-level 100
ip address 172.25.1.1 255.255.0.0
route inside 10.50.0.0 255.255.0.0 172.25.1.3 1
Ping from 172.25.1.100 to 10.50.17.10 is unreachable.
10.50.17.10 is existing beyond the router with ip address: 172.25.1.3, and it is reachable from the router.
Log says,
%ASA-3-106014: Deny inbound icmp src inside:172.25.1.100 dst inside:10.50.17.10 (type 8, code 0)
08-30-2005 03:25 AM
Please try adding the following command.
same-security-traffic permit intra-interface
Let me know if this helps.
Shijo George.
08-31-2005 11:47 AM
Thank you very much for your reply.
I tried both
same-security-traffic permit inter-interface
and
However, I still get this message,
In my case,
- IP traffic, not IPSec
- incoming and outgoing interfaces are the same (inside interface)
- At the inside interface, incoming traffic should be routed by static route to another hop on inside LAN. But it is denied by ASA.
Do you have any idea?
