ā02-17-2023 11:57 AM
Hello...new to posting here. If it needs to go to a different board please move.
I am working for a company that is attempting to harden it's routing/switching network by leveraging Radius authentication via MS Active Directory. I have been successful on configuring this for standard ios devices, but have yet to get the ASR9k's using XR v 6.3.3
here's my aaa config:
radius-server host 192.168.12.50 auth-port 1645 acct-port 1646
key 7 0333492B1207714A6501180B464B535E
timeout 5
aaa group server radius RAD_SERVERS
server 192.168.12.50 auth-port 1645 acct-port 1646
source-interface Loopback0
aaa authorization exec default none
aaa authentication login CONSOLE local
aaa authentication login default group RAD_SERVERS local
I have confirmed communication to the radius server. I have other config I can provide if requested. When trying to log in with AD credentials on the switch, I get an immediate access denied response.
Solved! Go to Solution.
ā03-01-2023 04:42 PM
i have replied to your new thread. so we close this here and pursue your issue on the new thread.
ā02-17-2023 12:03 PM
first try change the port
1812 and 1813
ā02-17-2023 12:31 PM
what radius server, is the radius server listening to 1645 and 1646 ?
Could you make sure the radius server is reachable with the Loopback0 address?
on the NAD/NAC what IP address was added in the radius? Loopback0 address?
ā02-17-2023 12:47 PM
yes, the loopback address is the authorized address for comms. I have done packet capture at my firewall and verified comms between the server and router on port 1645/46
I actually would have preferred using ports 1812/13 but when I used those ports to define the radius-server host, it would not commit the changes when I used that ip/ports in the aaa group server radius command. I had to define it on 1645/46.
ā02-17-2023 12:59 PM
can you share
debug aaa auth
ā02-17-2023 01:58 PM
what radius server ?
ā02-17-2023 01:17 PM
Here's the debug output from username and pw entry. I do know I am using correct credentials. From this output I can surmise the line is using the default authentication method. my credentials are passed to the server and they fail.
ā02-17-2023 01:47 PM - edited ā02-18-2023 02:57 AM
see my comment about bug
ā02-18-2023 02:56 AM
CSCum34024 : Bug Search Tool (cisco.com)
please check this bug
there is bug if the key is more than 22 then it will not work.
reduce the key and check again,
ā02-20-2023 08:05 AM - edited ā02-20-2023 08:18 AM
The key I have been using is only 15 characters. I also do not get the associated error message when using debug locald during login attempts.
ā02-20-2023 09:47 AM
for key I will double check
for the error message appear, can you more elaborate
ā02-20-2023 09:52 AM
from the bug's description:
Symptom: ASR9000 running 4.3.2. Radius authentification fails with the following message seen in 'debug locald', despite radius-server is configured and seen in UP state in 'show radius': locald_DSC[308]: EXITTING 'locald_send_v' with error [A247C800] 'RADIUS' detected the 'fatal' condition 'No server information is available'
When I run debug locald and attempt radius authentication, I do not receive EXITTING 'locald_send_v' with error [A247C800] 'RADIUS' detected the 'fatal' condition 'No server information is available'
This is what I mean when I say I do not get the associated error message
ā02-28-2023 03:04 PM
I have an update on this. I have installed wireshark on the MS NPS. I have confirmed I am getting access-accept packets being sent back to the routers.
If the router is getting these packets, why is the user not being authenticated? It makes no sense.
