1281
bcuryk
Beginner
C3750X TrustSec problem
I've configured 2 C3750X with SM for working together via vieber (switches in differents cities). I've used configurations from cisco guides. I'm using cts man command with/without cts cred. And it never works. Always I get this logs (and ports protocol go down when I put sap pmk options):
Feb 26 12:01:36.031: Conflicting CLI: CTS and Macsec are not allowed together
Feb 26 11:55:28.325: MACsec-CTS: macsec_cts_sap_session_stop Received SAP session STOP oninterface(GigabitEthernet1/1/2), clean up the SCs
Feb 26 11:55:28.325: MACsec API blocking the invoking context
Feb 26 11:55:28.325: HULC-MACsec: Entering macsec_req_local_handler req 64E8874:
Feb 26 11:55:28.325: HULC-MACsec: macsec_process_req : Req type: 3
Feb 26 11:55:28.325: HULC-MACsec: Process delete RxSC i/f GigabitEthernet1/1/2 SCI 6400F155F2440000
Feb 26 11:55:28.325: HULC-MACsec: RxSC not found (6400F155F2440000)
Feb 26 11:55:28.325: HULC-MACsec: Invoking the callback for req 64E8874
Feb 26 11:55:28.325: macsec_blocking_callback
Feb 26 11:55:28.325:  MACSEC_ERROR returned
Feb 26 11:55:28.325: Wake up the blocking process
Feb 26 11:55:28.325: HULC-MACsec: macsec_process_req : Req type: 1
Feb 26 11:55:28.325: HULC-MACsec: Process delete TxSC i/f GigabitEthernet1/1/2 SCI C89C1DE222440000
Feb 26 11:55:28.325: HULC-MACsec: TxSC not found
Feb 26 11:55:28.518: Hulc MACsec: No H/W Subblock
Feb 26 11:55:28.518: Hulc:Destroying the macsec subblock
Feb 26 11:55:28.551: Event notification 2
Feb 26 11:55:28.551: Received-AN: 0, Received-SCI: 0
Feb 26 11:55:28.551: Hulc MACsec: Notify port disabled event
What can be wrong or what I have to do to set up TrustSec between two 3750X?
0 REPLIES 0
