12-28-2004 06:54 PM - edited 03-09-2019 09:52 AM
Hi Everybody,
I'm having problem with pdm version 3.0(1),
I've entered access-list outside_access_in deny icmp any any , access-group outside_access_in in interface inside and some other commands, then i open the pdm under the access rules, it shows nothing, i think this is a bug, does it solve in new version of pdm? ;)
thanks a million
Tonny
12-28-2004 10:53 PM
PDM is now well trusted. IT has evolved from several versions now. There must be something wrong you are doing, or may be some bug
thanks
Nadeem
12-29-2004 04:46 AM
I am not sure,but is not ACL outside_access_in to be
implemented at the outside interface and not (as in
this case ) at the inside interface ?
Zdenek
12-29-2004 09:40 AM
i cant say unless i see your configs.
12-29-2004 05:13 PM
Maybe there's something wrong with my command:
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 100 permit ip host 192.168.1.9 192.168.100.0 255.255.255.0
access-list 100 permit ip host 192.168.1.2 192.168.100.0 255.255.255.0
access-list outside_access_in deny udp any any
access-list outside_access_in deny ip any any
pager lines 24
logging on
logging monitor debugging
logging buffered debugging
icmp deny any outside
mtu outside 1500
mtu inside 1500
ip address outside 10.1.1.2 255.0.0.0
ip address inside 192.168.1.1 255.255.255.0
ip verify reverse-path interface outside
ip audit name ATTACKPOLICY attack action alarm drop
ip audit name INFORMATIONPOLICY info action alarm drop
ip audit interface outside INFORMATIONPOLICY
ip audit interface outside ATTACKPOLICY
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool 192.168.100.1-192.168.100.254
pdm location 192.168.1.2 255.255.255.255 inside
pdm location 192.168.1.9 255.255.255.255 inside
pdm logging debugging 100
pdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 0 access-list 100
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 10.1.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
url-server (inside) vendor websense host 192.168.1.2 timeout 5 protocol TCP vers
ion 1
filter url except 192.168.1.2 255.255.255.255 0.0.0.0 0.0.0.0
filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0
http server enable
http 192.168.1.2 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
tftp-server inside 192.168.1.2 c:\cisco
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap client authentication LOCAL
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup **** address-pool vpnpool
vpngroup **** split-tunnel 100
vpngroup **** idle-time 5400
vpngroup **** password ********
telnet 192.168.1.2 255.255.255.255 inside
telnet timeout 60
ssh timeout 5
Thanks for helping
Tonny
