Cannot get web interface
bhughesiii
The problem I got is I have a client using Cisco's VPN client. He connects to another server and is going through a pix 515. The vpn authenticates, but when we try to pull up the web interface for an IBM AS400 it will not go through. Could this be a mis config on my pix, or is it an issue with the server being authenticated to?
micah
Can the client connect to other services through the tunnel? Can he ping the AS400?
Here is the deal. And I just found this out today. If you dial up to the internet and use the cisco vpn client from a public address it works fine. It is haveing trouble going through the pix on a private address. We havent tried pinging the AS400 yet I think ICMP is turned off. But we are going to try that, and if this other info helps then I will appreciate anything else you can tell me
Correct. If you are behind a 1 to many (PAT /NAPT) NAT situation then it will not work. You have to have a 1 to 1 nat translation for IOS or the firewall at this time. If you have a concentrator you can use IPSEC over tcp. The problem lies with the fact that the port information is encrypted so port address translation doesn't work. In addition to this for a firewall on a PAT/NAPT setup you need to enable ESP inbound on the public address in your firewall rules.
Thank you much. I will make the neccassary changes and see how it works.
