CAS and CAM command reference
rajbhatt
Level 3
Level 3
HI,
I am using latest CAM 4.7.2 and same CAS versiion .
Can anyone suggest a link to command reference for 4.7.2 .
Only a few commands are found in the config guides
Always using the GUI is not very helpful.
regards
Raj
Faisal Sehbai
Level 7
Level 7
Raj,
Clean access is different in this regard. The command line is used only to do the initial config and the bulk of configs are done through the GUI only. Data is all kept in the database to which the GUI talks, so there are no command line tools to configure the CCA per se.
HTH,
Faisal
I am not talking of command line tools.
I am saying when we troubleshoot NAC , say in CAM I am checking for a particcular file , I should know where it is located and we can use command line instead of GUI as TAC does .
Say suppose I want to restart CAM , in command reference , it should show init6 and init 0 in command referance.
Or do a debug in command line , take a capture stuff like that , or edit the interface parameters , but not from the setup menu
Where do i find the docuementation related to that .
reg
Raj
