CATOS and Clean Access
NAVIN PARWAL
Level 2
Level 2
Folks,
We are running the latest version of CatOS on our switches and trying to implement CCS(Package)solution. I see Mac-notification command in the CATOS,but I do not see linkup and Linkdown command for snmp in the CATOS, the compatablity matrix says that the version should work with CCS 4.1(1), Has anyone implemented CCS on CATOS.
chjanoff
Please open a TAC case for a timely response on code versions and matrix compatability. We did not use clean access in our PCI Solution for Retail so I do not have a reference for you.
chris.brooks
i think you are looking for the set port trap command
