Cisco 4710 ACE syslogs generating issue
I have 4710 ACE load balancer with three virtual contexts, i have configured the three contexts with the syslog configuration to send the logs to a syslog server as below:
logging enable
logging trap 5
logging buffered 7
logging host 10.x.x.x udp/514
I can see the logs generated from the admin context conly and not from the other two context, below is the show logging from two context:
switch/Admin# sh logging
Syslog logging:                 enabled
Facility:                       20
History logging:                disabled
Trap logging:                   enabled (level - notifications)
Timestamp logging:              disabled
Fastpath logging:               disabled
Persist logging:                disabled
Standby logging:                disabled
Rate-limit logging:             disabled (min - 0 max 100000 msgs/sec)
Console logging:                disabled
Monitor logging:                disabled
        Logging to 10.253.147.222 udp/514
Device ID:                      disabled
Message logging:                none
Buffered logging:               enabled (level - debugging) maximum size 1048576
Buffer info: current size - 1048576 global pool - 1048576 used pool - 1048576
                min - 0 max - 1048576
                cur ptr = 493382 wrapped - yes
switch/prodcar# sh logging
Facility:                       20
Fastpath logging:               enabled
Console logging:                enabled (level - debugging)
Monitor logging:                enabled (level - debugging)
Device ID:                      disabled
Buffered logging:               enabled (level - notifications) maximum size 0
Buffer info: current size - 0 global pool - 1048576 used pool - 1048576
                min - 0 max - 0
                cur ptr = 0 wrapped - yes
i think the issue with thw Buffered logging size but i dont know how to change that.
Also note that the software version is A3(2.0)
Hi Mohammed ,
You issue is :
Split the syslog resources between contexts.
As a workaround on the Admin context : clear logg
Dan
