05-10-2007 09:34 AM - edited 02-21-2020 03:02 PM
I currently have 5 sites that are connected via hub/spoke LAN-to-LAN connections with Denver being the primary site. We are looking to enable Remote VPNs using the Cisco VPN client. I have been able to connect to the main denver location, but cannot connect to any of the remote sites via the Remote VPN. I have all of the addresses for the remote sites listed in my split tunneling configuration. All of the firewalls are the ASA series using ASDM 5.2. Can this be done?
Jack
05-10-2007 09:44 AM
So you want to go over ra vpn to denver then go over l2l tunnels to remote sites? A few things, you must define the traffic as interesting in your crypto acl's for the l2l tunnels and also have to enable the following.
same-security-traffic permit intra-interface
this will allow traffic to enter and exit same interface. (outside in this case)
05-10-2007 10:25 AM
This may help as well, this is for pix but is the same for ASA.
Please rate if these help.
