08-24-2017 05:34 AM - edited 03-10-2019 12:52 AM
Hi respected members,
I need your suggestions to get the following features from WAF (Web Application Firewall). I have no idea
about that.
which solution will provide these features.
1) Bruteforce attack detection.
2)Wrong password and username detection report.
3) Default signature based SQL and XSS injection attack detection.
08-24-2017 08:37 AM
Cisco does ot make a WAF per se.
Item #3 is certainly detected and blocked by a Firepower NGFW (FTD or ASA with Firepower service module) or NGIPS (Classic appliance running Firepower software).
08-25-2017 01:53 AM
Thankyou for your reply marvin.
you mean cisco does not make a WAF (Web application firewall)
if so than what do you suggest we should look for. i think than we need some other vendor for WAF.
OK. We have cisco 5516x with firepower.
08-25-2017 03:35 AM
Correct - Cisco does not make a web application firewall (WAF).
As I alluded to, the Cisco Firepower product line does have some functionality that may be traditionally called part of a web application firewall (such as protection against SQL injection and cross-site scripting). However it is not intended to be competitive with products that are purpose-built as a WAF.
11-28-2018 07:02 PM
F5 ASM
02-27-2019 02:32 PM
This is probably long after a useful timeframe however cisco does (and has) made a WAF (Web Application Firewall) called Web Security appliance (WSA) previously known as SMA.
Datasheet here: https://www.cisco.com/c/en/us/products/collateral/security/content-security-management-appliance/datasheet-c78-729630.html
It is available in both Physical and Virtual form factor.
02-27-2019 08:01 PM
WSA is not a WAF.
SMA is the Security Management Appliance and is used to manage WSAs and ESAs. It is not another name for the WSA
