10-02-2006 02:35 PM - edited 03-09-2019 04:23 PM
Will the configuration below allow CLI access? Or will access be prevented because there is no password configured?
NOTE: lines 0 4 are configured with password.
line vty 5 15
transport preferred all
transport input all
transport output all
Solved! Go to Solution.
10-02-2006 07:08 PM
10-02-2006 07:08 PM
hi
to access a vty line you need a password configured.
10-03-2006 02:58 AM
if you configure the aaa with the following commands
aaa authentication login default local-case
aaa authentication login userauthen local-case
username admin privilege 15 password admin
it isn't neccessary to configure a password on the vty lines.
Regards.
