144
cashqoo
Beginner
client connection problem
I have a VPN set up in office.
Clients are able to connect from remote site (behind another PIX;using private ip addres), but unable to ping or connect to any devices.
client's statistics shows
Encrypted Packets >0
Decrypted Packets =0;
seems like not receiving any vpn packets.
After i configure NAT (on pix) using public to private IP address, the problem was resolved.
like to seek advise on what to do, in order to allow clients w/o additional configuration on other PIXs.
2 REPLIES 2
mpalardy
Participant
Doing nat is the right thing to do. Do you also encrypt the interesting traffic?
morgsizun
Beginner
do you see discarded packets in your client's stats?
In this case , il might be a problem with your default gateway.
When the tunnel is up , the default gw must be your VPN Adapater IP adress . Sometimes the default gw stays your lan connection's gw .
A solution is to force your lan connection's metric to 2 to force your VPN Adapter to become your gw.
Morgan Sizun
Content for Community-Ad
