Config Problem
brivero1190
Beginner
Beginner
Trying to import a profile and am receiving an error 22 "unable to import connection Entry. I have uninstalled and reinstalled already and that was no help. Any suggestions would be great
wong34539
Frequent Contributor
Make sure you reboot after installing VPN If you have the profiles on a PC or a disk, just copy them into the following directory:
/etc/CiscoSystemsVPNClient/Profiles/ . No need to import them
Try restarting the service.
BeemenBeshara
Beginner
Beginner
Although this is a 5 year old post, I would like to add  comment
This problem can occur if the path to the pcf file contains characters from a language that is not supported by your local.
This happened with me because my locale is Arabic and the file path had a Danish letter
Recognize Your Peers
