05-11-2004 07:38 PM - edited 03-09-2019 07:20 AM
I am trying to connect to my server at work through VPN client version 4.0.4 on my XP pro machine(5.1.2600).. I connect just fine but I can't see the remote server in network places and I can't map it as a network drive..
I am using group authentication with a password..
Can anyone help
05-12-2004 03:33 AM
can you ping it by:
ip address?
hostname?
fully qualified hostname?
are you running wins, and if so, are you passing that wins server parameter to vpn clients?
05-14-2004 07:14 PM
I went into command prompt and pinged the ip address of my server and I got a response when I ping the host name it says it can't find it. Not sure what a fully qualified host name is
not sure what you mean by passing win server parameter
