Converting "except" entries
iholdings
Greetings,
I have the following rules (masked here) applied to my PIX to prevent the use of pure AOL clients that have the ability to circumvent AAA. The problem is, PDM does not support "except" entries or more than one outbound command bound to a particular interface. Is there a way to convert these entries to preserve the rules and enable PDM? Thanks.
outbound 1 permit 0.0.0.0 0.0.0.0 0 tcp
outbound 1 except 0.0.0.0 0.0.0.0 5190 tcp
outbound 1 except 0.0.0.0 0.0.0.0 5190 udp
outbound 1 except 0.0.0.0 0.0.0.0 5191 tcp
outbound 1 except 0.0.0.0 0.0.0.0 5191 udp
outbound 1 except 0.0.0.0 0.0.0.0 5192 tcp
outbound 1 except 0.0.0.0 0.0.0.0 5192 udp
outbound 1 except 0.0.0.0 0.0.0.0 5193 tcp
outbound 1 except 0.0.0.0 0.0.0.0 5193 udp
outbound 10 deny x.x.3.8 255.255.255.255 0 tcp
outbound 10 deny x.x.3.0 255.255.255.248 0 tcp
outbound 10 deny x.x.206.9 255.255.255.255 0 tcp
outbound 10 deny x.x.206.5 255.255.255.255 0 tcp
apply (outside) 10 outgoing_src
apply (outside) 1 outgoing_src
apply (inside) 1 outgoing_src
apply (inside) 10 outgoing_src
thomas.chen
Level 6
Level 6
You’ll probably need to use Policy Manager or Command Line. Maybe a future version of PDM will be more robust. Have you checked with Cisco?
thomas.chen
Level 6
Level 6
