Creating a secure channel between (2) WS-C3850-24T using (2) LH fiber modules located in the C3850-NM-4-1G
Richard Stanger
I wish to create a secure channel between (2) WS-C3850-24T using (2) LH fiber modules in the C3850-NM-4-1G. I originally wanted to use MacSec but I am questioning now if MacSec is even possible on the 3850 (unable to get all the commands to work). Can anyone confirm if MacSec is possible on the 3850 with this module? If you have configured this, let me know how.
On the fiber module port, I am unable to issue the commands:
switchport  trunk encapsulation dot1q
as well as the “gcm-encypt” part of sap pmk <Hexdec> mode-list gcm-encrypt
 If it isn't possible, is there another way recommended? Site-to-Site VPN?
MacSec is desirable due to the speed but if it can't be done, so be it. I am getting conflicting information online and with Cisco.
Rick
This command is only available on switches that also support the legacy ISL in addition to dot1q. Normal behavior.
For MacSec, I never implemented it on that module, but are you running a recent IOS? In first versions it was not implemented in the software and was added in a later release.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/37e/consolidated_guide/b_37e_consolidated_3850_cg/b_37e_consolidated_3850_cg_chapter_01110101.html#task_CCBD6C0C4B07493BB5531708AE622C61
BrianSekleckiGE
Did you ever make it work?
