CSA 4.0.3 to 4.5 Problem
david.lawrence
Level 3
Level 3
I did the upgrade to VMS 2.3 and then installed the CSAMC 4.5. The upgrade seemed to go ok, although it didn't like my license files for some reason. These were reinstalled after a reboot without an issue.
I get the 2 MC's for CSA 4.0.3 and for 4.5. I created a scheduled upgrade in the 4.0.3 MC to automatically upgrade my clients to 4.5. (did this when i went from 4.0.1 to 4.0.3 which worked a treat.
However, I'm getting a problem with the upgrades. Clients security is enabled and client seems to poll, but doesn't get upgraded. When i check the log files out from the 4.0.3 client, it talks about an issue with the certificate when communicating with the VMS server. Any one had a similar issue and got a workaround?
I manual upgrade works fine and the 4.5 client polls without an issue.
TIA
D
umedryk
Level 5
Level 5
What is the exact error message that it shows in the log ?
I'll check one of the logs on Tuesday and post back. Monday is bank holiday here in the UK.
regards
D
Here is a copy of the csalog file from one of the clients.
TIA
D
