CSA 6.0 And remote desktop
cplatt01
I upgraded to CSA 6.0 agent on my PC and when I attempt to remote desktop into a server, I am not able to. I looked in the CSA logs and there is not a log message that states the action was blocked. I uninstalled CSA and I am able to RDP. Has anyone else experienced this, and is there a way around it?
There were no events in the management console as well.
Thanks in advance!
matt_nels
With CSA 6.0, the Network access control rule [1635], was key to this access. The application is identified as:
svhost.exe -k termsvcs
Termsvcs is your terminal services/RDP. Just add an exception to this rule allowing the connection using host addresses.
tsteger1
Level 8
Level 8
I have it installed on a Vista laptop and RDP works ok.
Did test mode not help?
Mstsc.exe also needs to be allowed to capture all keystrokes (it is by default).
I did run it in test mode, but did not see any events for this type of behavior. I will continue to check it out.
matt_nels
The strange thing was that it only happend when I was connected via VPN.
