CSA and 64 bit
madjack01
Does CSA v6.0 support 64 bit windows
Hi Matt,
Solaris 10 is supported as of 6.0.1:
http://www.cisco.com/en/US/docs/security/csa/csa601/release_notes/CSA601RN.html#wp195836
64-bit Windows is a future release so you won't be able to get a definitive answer on the forum (Cisco doesn't provide statements around future releases.) My recommendation is to talk with your account team and have them keep you posted on the progress toward 64-bit Windows support.
Josh
matt_nels
No, not at this time.
Anybody with Cisco reading the forum have a timeframe of when 64-bit "may" be supported? How about Solaris 10 support?
Hi Matt,
Josh
timothyweaver
So far, it doesn't seem to. Cisco really should clarify that in the datasheets for the CSA agents. Right now, it just says "XP" and "Vista" but no mention that it's 32 bit only.
Another thread here had someone claiming that their Cisco rep told them August 2009 for the 64 bit CSA. That's quite unverified though.
cschweigert
Does anyone have any update on the support of the 64 bit OS? I am looking for support spec
ifically for Windows OS and Ubuntu.
