hi there
any reply ?????
Hi Alkabeer,
You can view real time syslog via ASDM. ( For PIX, ASA, or FWSM in the Security Manager device inventory).
In an ASDM device manager launched from Security Manager, you can monitor system log messages in the Real-time Log Viewer window and the Log Buffer window. You can select a syslog message displayed in either window and navigate to the access-control rule in Security Manager that triggered the message, where you can update the rule as necessary.
The Real-time Log Viewer is a separate window that lets you view syslog messages as they are logged. The separate Log Buffer window lets you view messages present in the syslog buffer.
For IOS Router syslog, You can use SDM.
In an SDM device manager launched from Security Manager, you can view a log of events categorized by security level under the Syslog tab of the Logging window. You can select a syslog message and navigate to the access-control rule in Security Manager that triggered the message, where you can update the rule as necessary.
The Monitor > Logging option in SDM offers four log tabs; Syslog is the only one of these offering the Security Manager access-rule look-up option. The router contains a log of events categorized by severity level. The Syslog tab displays the router log, even if log messages are being forwarded to a syslog server.
And
In CS-MARS, You can generate reports to see devices syslogs.
Keep Smiling, Peace
For CS-MARS,
Go to Query, Change the Query Type to : Event Raw Messages ranked by Time, Real Time(raw events)
Then click on the "DEVICE" (which is default ANY) and select your ROUTER there.
Then click 'Submit'
Please rate if helpful.
Keep Smiling, Peace
Hi Gurpreet,
I am running MARS ver 6.0. I do not see Query Type to : Event Raw Messages ranked by Time, Real Time(raw events).
Any idea? Or any other way of verfying if any device is sending syslog messages to MARS?
