Data Plane filter SNMP traffic
WiKiD
Hello everyone,
Scenario:
Router 1 (Edge IP 1.1.1.1)
is connected to ISP Router 2 (IP 2.2.2.2) via BGP,
and via Tunnel to Internal Router (IP 3.3.3.3)
It´s now that transit traffic to SNMP Port 161 and 162 hits the Internal Router, means malicious traffic
(port scans / whatever).
My Question is:
How would a transit ACL for the Data Plane will look like to filter/block these attempts ? and how is it applied to the Control Plane? Or would a Interface ACL inbound to the Router 1 (Edge) to the job. Some helpful advice would be great. Thank you all.
Cristian Matei
    It's recommended to filter that kind of traffic, inbound on your Edge router, before it hits the Internal router; this would be a regular ACL to deny traffic destined to UDP 161 and UDP 162 and allow other traffic that you want/need.
   At the same time, if you want to offer better protection to your internal router, which may be "attacked" from the inside network, additionally to what i stated above, you should configure control-plane protection on your Internal router and restrict which management protocols do you allow, and from which IP's.
https://tools.cisco.com/security/center/resources/copp_best_practices
Cristian Matei.
Cristian Matei
Cristian Matei.
Thank you Cristian,
that´s sound good.
