01-23-2003 01:59 PM - edited 03-09-2019 01:49 AM
hi me again. sorry for the newbieness of my questions:
in the following show route command results, i'm having problems figuring out if it's right. Info given to me by MCI,
default gateway: 54.54.54.190 changed for safety reasons
subnet mask : 255.255.255.192
outside interface = 54.54.54.129
inside interface = 172.16.10.1
interface3 = 172.16.20.1
interface4 = 172.16.40.1
interface5 = 172.16.50.1
i want the default gateway i'm assuming to be 54.54.54.129
here's the results, and is this right? for some reason the second line doesn't look right for outside....
PIX515URINTEL01(config)# show route
outside 0.0.0.0 0.0.0.0 63.123.35.190 0 OTHER static
outside 63.123.35.128 255.255.255.192 63.123.35.129 1 CONNECT static
inside 172.16.10.0 255.255.255.0 172.16.10.1 1 CONNECT static
global01 172.16.20.0 255.255.255.0 172.16.20.1 1 CONNECT static
surveys01 172.16.40.0 255.255.255.0 172.16.40.1 1 CONNECT static
vpn01 172.16.50.0 255.255.255.0 172.16.50.1 1 CONNECT static
01-23-2003 02:42 PM
It looks fine
This line is telling you the default route of the Pix - .190 as per the MCI information.
This line is telling you the details of the connected IP network on the outside interface - .129 being the outside interface's IP address and that this interface is the exit to get to that network.
Kev
01-23-2003 03:10 PM
Kev,
Thanks for the input.
One more question. Does the 0 hops in the first line need to be 1?
01-23-2003 03:17 PM
Yes, thats correct - it should indeed be 1
Kev
01-23-2003 02:45 PM
It is correct. The default gateway should be the .190 address and the line :
is just saying that the 63.123.35.128 255.255.255.192 is directly connected to the outside interface of you PIX.
Kevin
