Deny UDP Reverse Path
akusuma1
Dear expert,
When we turn on the syslog, we see a lot of messages as "%PIX-1-106021: Deny UDP reverse path check from 192.168.0.208 to 10.17.18.150 on interface inside". Is there any explanation for this ?
m.sir
Level 7
Level 7
Reverse path check is used when is packet comes from network behind interface and this network is not in firewalls routing table...its antispoofing feature... What is 192.168.0.0 range in your network???? If you dont have such network it could be some machine in your "legal" network with 2 networks card and second is addressed with 192.168.0.208 (and routing is not properly configured) - its could be explanation how 192.168. network could appear on your firewall
M.
Hope that helps, rate if it does
