06-17-2010 03:32 AM - edited 03-09-2019 11:01 PM
Is it possible to configure NAS (on NAM perhaps) to assign IP addresses to clients on the trusted side - i. e. to act as a DHCP server for the trusted side subnets or change the address through the NAC Agent after the posture assessment is over?
06-17-2010 06:28 AM
Boris,
I'm assuming from the question that this is an OOB setup. If so, the agent requests a new IP if you're using Role-Based VLANs with VGW. In OOB RIP setups, it will also request a new IP when it gets on the final VLAN.
CAS giving out IP addresses on the trusted subnets would not be possible, or even a good idea!
HTH,
Faisal
06-24-2010 04:19 AM
Faisal,
Your assumption was correct, this is an OOB setup. Your reply confirmed what I suspected already.
Thank you for your help.
