I have an access HP switch which is connected to an Cisco Backbone switch. The dhcp server and the clients are in different vlans.
We just enabled the dhcp-snooping on our HP switch but next day some of our clients could'nt get ip address. When I checked with my pc I also couldnt get ip. But when I check the binding table I see some clients could get ip address. So what can be the problem? Also I do not see any drops in dhcp-snooping stats. As soon as I disable dhcp-snooping I can get an ip.
I also wrote this problem to HP forums but from there I could not get any response.
dhcp-snooping
dhcp-snooping vlan 1
interface 10 //this interface goes to the backbone switch (Cisco, and there is an helper address is configured)
dhcp-snooping trust
Packet type Action Reason Count
server forward from trusted port 16
client forward to trusted port 10606
server drop received on untrusted port 0
server drop unauthorized server 0
client drop destination on untrusted port 0
client drop untrusted option 82 field 0
client drop bad DHCP release request 0
client drop failed verify MAC check 0
