03-25-2008 09:21 AM - edited 03-09-2019 08:21 PM
we've are using with success DHCP Snooping with DHCP relay configured...but I was wondering if the DHCP Snooping feature is working also on a L2 network (composed by different switches) where the DHCP Server is on the same VLAN as the client?
I know that Server have to be in a dedicated VLAN but VLAN segmentation DHCP Server - client is planned in a second step...
Thanks for your suggestions!
Solved! Go to Solution.
03-26-2008 11:34 PM
Hi Omar,
The DHCP server can be on the same VLAN as the clients, no problem with this.
You need to configure the DHCP server's port as trusted with the following commands:
conf t
ip dhcp snooping
ip dhcp snooping vlan x
interface fastethernet x/y
ip dhcp snooping trust
fastethernet x/y will be the port where the DHCP server should be located.
Cheers:
Istvan
03-26-2008 11:34 PM
Hi Omar,
conf t
ip dhcp snooping
Cheers:
Istvan
02-18-2014 01:20 AM
Mr. Istvan,
I want to ask what if for examplre, there is this layer 3 4506-e switch acting as a dhcp server for two vlans. vlan 5 and 6. and it configured to have two different default router for this two vlans respectively. how can i configure it?
